How to remove Apache Struts entirely from Pega install?
Hello, my client needs to completely remove Apache struts from their Pega environment.
“…We do use the SMA console. Are there other versions that don't have struts installed?
If we did not use SMA, are there other options to be able to manage the agents, settings etc?
Is there an option to remove Apache Strut references within the WAR files to completely remove struts but continue using SMA? ..”
making I indicated that Pega 7.4 is making use of Struts in SMA component only. But they use it. Thank you for our help.
