How to refresh the harness/section automatically
It has a disable FLG and the section/harness will be disable if the FLG is true.The FLG will be changed by maintenance personnel so that the section/harness's disability must be changed automatically.
My plan is use the disableCtrl datatype to control the disable flg and use the refresh condition(on datapage proeprty value change)to achieve the auto refresh.But it dose not work when I change the flg in the disableCtrl db.(I have made the DataPage Reload if older than 1s).
If my plan is impossible?If it has other way to achieve the refresh automatically
