Sun Life Financial
Sun Life Financial
Sun Life Financial
Posted: Sep 25, 2019
Last activity: Sep 25, 2019
Last activity: 25 Sep 2019 18:43 EDT
How to refer clipboard properties in text file type with .js extension
How to refer clipboard properties in text file type with .js extension.
Based on a property value of cipboard, we supposed to execute block of statements from a text file with .js extension. How can e refer clipboard value in text file rule type.
There are a number of ways to do this. Two of them include:
1) Use an ajax call to ask the server for the value of some property. This would be appropriate if the property is not likely to have the value when your page is first loaded, so you need to ask later.
2) During the staging of the script, do something like this:
var valOfGreeting = "<pega:getValue param=.Greeting/>";
The idea is that you use a pega tag which gets evaluated as the script is being staged so that by the time your script is staged, the above line is seen by the browser as something like
var valOfGreeting = "hi there";
