CGI
How to pass Form data in a connect rest rule
Can someone please explain how we can pass form-data as a body in a connect rest rule. We have tested the service from postman with the attached configuration and has worked. Now we want to test the same from Pega. In a connect rest rule under post method ,inside the message data section we can refer the following
1. HTML Stream
2. JSON
3. XML stream
4. Constant
5. Clip board
to pass the Form data, do we have to create an HTML stream rule and then pass the same in the connect rule?
