how to parse file in JSON format and put data on clipboard
Is there out of box activity that help to parse a file in JSON format and put data on clipboard?
We are using 7.3SP1
We are using 7.3SP1
We have one RUF is available with name ConvertStringToPage.
Using that function we can convert the json string to page
Assuming the content of the JSON file is already stored in a property somewhere on clipboard, you can create a (JSON) Data Transform (Create > Data Model > Data Transform. In the Data model format field, Select JSON), define your external data model to internal data model mapping and pass the value of that property as jsonData parameter of your JSON data transform; PRPC will automatically parse JSON and follow your mapping to map the data on clipboard.
[1]https://community.pega.com/sites/default/files/help_v731/procomhelpmain.htm#rule-/rule-obj-/rule-obj-model/definition.htm
