Hopkins Software Pvt. Ltd.
Last activity: 29 Mar 2023 4:41 EDT
How to open External website on button click?
Hi Everyone,
I have a drop down control and having options like Increase immunity, skin glow and so on. My requirement is when I was select the drop down control and click on button then related websites are opened this not a local action. How to do this
Updated: 29 Mar 2023 1:45 EDT
Evonsys
Updated: 23 Mar 2023 2:07 EDT
Evonsys
@NAGARJUNA Saidu Please refer to the below URL for reference. You can try giving the URL directly without dpage.prop also. But dpage.prop is the better approach
Hi Anoop Krishna. I was tried like your posted link. But I was failed. Can tell me once again
Evonsys
@NagarjunaS16644648
Here our aim is set a property with URL from a data page.
1. Create a dpage
Source Data Transform->
Parameter -> Type
When Param.Type=="Diabetes"
Set property-> .URL = "Diabetes related URL you have"
When Param. Type=="skin"
"Skin related URL you have"
2. Open your dropdown cell-> action set->
--->Post Value
----> Run Data transform, here set URL from dpage
.pyNote=Dpage [parameter:.yourselecteditem].URL
So if Diabetes, diabetes URL will be set, if skin, skin related
3. Now in open URL in new window -> use. pyNote in alternate domain.
Hi Anoop Krishna. Thank You for your response. when I'm Creating Data page source is Data Transfer. Here my problem is creating data transfer under Code-pega-List class or our actual information class Apollo-Data-AdditionalInfo class.
Evonsys
@NAGARJUNA Saidu you can make your dpage as page(not list) structure and class Apollo-Data-AdditionalInfo.
Bits in Glass
@NAGARJUNA Saiduadd on click event on your button and use Open URL in window
@NAGARJUNA SaiduAll the required details are maintained in a table
how to open this urls on button "View Tipps" click
Updated: 24 Mar 2023 3:12 EDT
Hi @NAGARJUNA Saidu ,
On click of button,
On change of Dropdown,
D_Links[RequestAdditionaInfo: .RequestAdditionalInfo].Url
@UdayReddyGunthala where did I call this Data transfer? I'm not able set this D_Links[RequestAdditionaInfo: .RequestAdditionalInfo].Url
@NAGARJUNA Saidu You need to create a data page for your links table. Name the data page as D_Links with request additional information as the parameter. Then as @UdayReddyGunthala suggested, on click of view tips button, add an action for opening the url in a window, in alternate domain url field you should load the url from table using the data page that you created with following config:
D_Links[RequestAdditionaInfo: .RequestAdditionalInfo].UrlAssuming RequestAdditionalInfo is the property used for the drop down. You may also need to do a post value action for change event for the dropdown control.
@NagarjunaS16644648
1. Create a dpage
Parameter -> Type
--->Post Value
