Bankofamerica.com
Bankofamerica.com
Bankofamerica.com
Posted: Aug 7, 2017
Last activity: Nov 6, 2018
How to Open excel and read the value in the cell
I wants to open the excel file and read the value in B1 cell and assign this value to application start path.
You will need to add a MicrosoftExcel component to you solution, it is found under Pega Robotics Connectors in the toolbox. Set the properties to open you excel file. Then you can read the value from B1 and place in the Path of the adapter, assuming this is a windows adapter.
