Princeton Blue BPM Solutions
Last activity: 28 Jul 2017 2:33 EDT
How to insert record into Excel (next empty row)
I implemented an automation where that automation reads data from the PDF and write those date into Excel Sheet.
When again I read the data and trying to write into same Excel file, All data are replacing with the previous one(records insert in same row) because cell value is hard code.
"I want to insert the record in the next empty row" so the previous record will not change.
I have also attached Automation. Please find the attachment and suggest where I need to change the flow and which method requires.
In your automation you are always setting the same cells. Use a counter variable to increase your row each time you write it. Here is an example:
