capgemini
Last activity: 16 Jul 2019 7:32 EDT
How to implement DWA ?
How to implement DWA ? I tried the same way mentioned in pdn,but I am not able to trigger any mail.Can anyone describe briefly in step by step process.
Raghuvamsi
***Moderator Edit: Vidyaranjan | Updated title***
Hi RaghuVamsi,
If you can upload the steps or screenshots, then we would be able to understand more on what is missing
Ujjwal
Could you please check if the below article helps:
https://pdn.pega.com/how-implement-directed-web-access
Thanking you,
Venkat
Amaeyaa Technologies Inc
Hi Janav,
How do you implement DWA in PEGA 7.2? The above link was for an old version of PEGA.
Hi Janav
I have a question regarding DWA. I have a requirement where i send in the same email to 5 different people. They enter a value in a field on a form and submit. I created an external party and concatenated the emails in it's Data Transform. Now when they submit the form, i want the value they entered to populate a page list data type (It has 7 columns). How do i know who entered which value (since the same form goes to 5 different people) and how do i populate the column in the correct row?
Acel Solutions
Hi mate
The Link posted by "Janav" is really helpful you could also try the below link
@ https://collaborate.pega.com/discussion/dwa
K L University
Hi All
As Shamila Mentioned I also got the similar type of requirement ,When the email is sent to different people how to know who have filled out the form.
Thanks in advance
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
Delta Denta
Can i use DWA for external user to create an assignment or WO, i.e. when flow is initiated by external user and not from pega ?
You cannot use DWA to create assignments from mail (not from PEGA). Through DWA you can process the assignments from mail created by PRPC
