BPM Company
Last activity: 17 Feb 2021 10:12 EST
How to get values of published channel page
Hi all,
Whenever I create a dynamic layout and subscribe it for a channel, I can see only possibility to filter channel's messages by its property value.
But how could I get other values from channel's message?
Lets say, I have an activity which publishes notification:
And in another case I have a section with the dynamic layout:
How could I get the second property (SubscriptionCaseID) from the channel TestChannel (let's say, to assign it to other work object's property)?
BPM Company
yiiihaaaa, I found it! :)
the problem is solved by providing to the callback an event in a form "javascript:event"
That's how it should looks like:
When you eventually implement your callback action/activity, did you try referencing SubscriptionCaseID then?
Krzysztof Lenarcik
BPM Company
Hi Rett,
First of all, that makes no sense - I don't have a clipboard page with that property in my thread/requestor/node. It must be a property on Channel's page, right?
Second - yes, I tried it :)
Jose Navas
You are correct, I overlooked this fact. You will not be able to guarantee it will be the same thread/clipboard context at that point in time (and in the majority of cases it will never be)
BPM Company
any other suggestions?
BPM Company
My thoughts so far:
since it's a push notification, it uses WebSockets to notify the subscriber. That's why it will not be reflected on Clipboard because Clipboard represents the server's memory, which is not accessible from a client (without refreshing).
Thus, the only way to access the payload of a message is through JS.
But even though I created a JS function with several input parameters, I see that the callback does not push an event object to it.
Here's the callback's configuration:
Here's my JS function:
My thoughts so far:
And here's the output in the console:
As you may see - nothing. Seems that "event" and "payload" are not keywords. If I leave it blank, also no effect. If I'd not provide it at all - again no results :\
Would appreciate any suggestions
BPM Company
Rosangela Valenzuela
OCBC
BPM Company
Unfortunately, I was able to use the channel's properties only in the callback function. In it, I run a data transform, where I propagate the page with all content. Byt this DT, you could set all needed values on the clipboard and use it afterwards
OCBC
BPM Company
Not exactly, it will be in a.details.response. Here's the function (instead of 'a' I use 'event'):
function migrationNewDeploy(event) {
// i have 4 properties in the channel:
// - pyID
// - pxReturnCode
// - pxHostName
// - pxReturnValue
var payload = event.detail.response;
console.log(payload); //to check what's in the channel
// here's how can u use properties from the channel
var options = {
name: 'AddNewJobToMigrationList', // data transform name
parameters: [
value: payload.pyID,
isProperty: false
value: payload.pxReturnCode,
isProperty: false
value: payload.pxHostName,
isProperty: false
value: payload.pxReturnValue,
isProperty: false
event: this.event
pega.api.ui.actions.runDataTransform(options);
Snehasis Panda Ketan Deshmukh Satish Ananthuni
OCBC
Hi, Thanks brother. It works :)
