IT
How to export pagelist from Clipboard tool to excel/csv?
do you have any suggestions or do we have any reusable stuff to export pagelist, displayed within Clipboard tool, to an excel/csv file?
Thanks in advance,
Giuseppe
Message was edited by: Vidyaranjan Av | Included category
Perficient
I am not able to access above link, could you help me in getting access to it?
Yagesh
PEG
PL
Below is the answer given in the above link shared by Haritha Damarla
i created my own activity in which i cam calling pxConvertResultsToCSV activity by giving step page of type code-pega-list. Then passing pxResults as parameter for list property for this activity.
On button click,I am refreshing the section by calling my own activity.
Personal
By Using the way you suggested i am getting only the page properties in excel file,i am not able to get the pageList propeties how to achieve that any suggestions?
Aakash Talreja
Ernst & Young LLP
call MSOGenerateExcelFile on a button.
In Param 'FSFileName' give name of the generated file for eg. "Test.xlsx".
In Param 'TemplateRFB' give name of a binary file for eg. "Excel!Test!xlsx".
In this binary file upload a excel sheet which contains property references for its columns like {.pageListName().PropertyName input} .
Then click the button on the UI.
LTI
I have followed your mentioned approach for generating the Excel file from Page List. But, i am getting an Error saying "No Stream to display". What could be the reason.
Please find the attached Screen print:
any help would be appreciated.
KSR Prasad
Sun Life
I am not able to find pxConvertResultsToCSV activity, please let me know the class name
Infosys
Activity belongs to @baseclass, you can try to call as - Call @baseclass.pxConvertResultsToCSV
Virtusa Corp.
I tried this approach for a simple Code-Pega-List and it worked fine. Now my question is if I want to export multiple cases and each case has nested lists would this work? For example inside the case apart from case properties I have a list of items.In this scenario generated file was empty. I'm not sure if the method I did it was wrong or that this approach won't fit into that scenario where you have nested lists. Please let me know
Mastercard
Did you find a way to export multiple cases and each case has nested lists? would this work? If yes can you please share the steps or syntax?
