  COFORGE DPA AUSTRALIA PTY LTD
Last activity: 24 May 2017 15:31 EDT
How to enable the UI Inspector on Modal Dailogues.
When we are performing the export of the application when the user clicks on the Export button it will open the separate tab with progress bar.
needed to inspect with UI inspector the opened Tab.
pranavi.
Hi Pranav,
pxuiinspector privilege is required to enable the live UI.So,by default it should be present for the new tab.For modal dialog,there will be not be UI Inspector specific to Modal dialog but we can use the UI Inspector present on the portal(designer studio/case manager).
Please let me know if you are not able to navigate the UI inspector to modal dialog.
Please share the screenshot
Hi sarab,
The pxUIInspetor privilege is present i am able to inspect the rules but when the rule opened in the modal dailog i am unable inspect.
please find the screen shot attched
HI Pranav,
I have tried exporting the application at my end but the export status with the toggle bar is opened just below the perform extract button and I am able to inspect it.I also checked for other instances where the seperate tab gets opened like when running the report and the UI Inspector is available.
Please find the attached screenshot
i tried the export by package when we perform all the steps once the user clicks on the Export it will open in the new modal dailog. in the previous reply i mentioned the screen shots.
If we export using the package you will be able to reproduce the issue.
Hi Pravani,
May I know your business reason to want to enable the UI inspector here? Are you just curious how this UI is constructed? Or are you facing an issue with this feature, and trying to debug it yourself?
  SaiKishore Yagnamurthy dhanalakshmi s Raghuvamsy Pakam GUDIVADA Gudivada Afroze Jahan and 3 More
Hi Rett_Hean
This is not for the business requirement just i want to know whether any configuration is there to enable the Live UI on the modal dailog.
Hi Pranavid,
There is no configuration available to enable the Live UI on modal dialog.The Live UI visibility is only dependent on the pxUIInspector privilege and pyenableUIInspector when rule.
