WellCare
Last activity: 28 Dec 2015 16:07 EST
How do we query the PRPC DB for hotfixes not installed by the Hotfix Manager?
I am trying to find out if there are any hotfixes that were installed in the system which were not installed by the Hotfix Manager.
I would suggest examining instances of the Log-PegaRULESMove class in the system.
as per the Help documentation, "Log-PegaRULESMove concrete class contains one instance for each execution of the Import Archive and Export Archive tools. Properties in each instance identify the date and time the execution started, which user ran the tool, a record count, and the name of the ZIP file used. "
From this you should be able to identify any archive that has been imported to the system (including hot fixes not added via Update Manager) using the Import (or Export) facility.
Gareth
Not sure this is possible, why are you doing this? To identify framework related hotfixes (normally installed by import directly)? Eventually we are going to make all hotfixes unified, including frameworks, but we are not there yet.
WellCare
Hi Kevin,
Yes, that is exactly why. There is a requirement for me to find out if any hotfixes were imported without going thru the hotfix manager.
WellCare
Hi Kevin,
Do you know if this can also be done for third-party jars?
Thank you,
Irrespective of whether it is a DL item or HFIX jar containing rule changes , it should ideally be stored in the ServiceExport directory on the server.
So that should be one quick way to check whether you have uploaded the framework HFIX es into system.
Also, you can try importing the HFIX again by checking " Enable advanced mode to provide more granular control over the import process" so that at runtime you can see the name of the rules which system wants to import to system.
At this point, if you see a message which says " Instances already loaded " then you can assume that the particular HFIX is already loaded.
WellCare
Hi Santanu,
The temp directory had been cleaned already so I could not find the jars there; that is why I was asking if there is a way to query the DB for certain tables that might contain such info.
Hi
Check pr_engineclasses to check for the jar files imported and installed to system
JPMC
WellCare
Hi Ashish,
I am going to give it a try and let you know if this works for me or not.
Thank you,
WellCare
Hi Ashish,
I was not able to find what I was looking for with that approached.
Thank you,
Fabian.
JPMC
Hi Fabian,
Its interesting that it did not work for you.
May i know the hotfix number which you just installed through import and it is not shwoing in the product list in export wizard.
Usually all PRPC hotfixes will be installed through the hotfix manager and the frameworks hotfix will be imported directly which are usually just products, so should appear in this list.
Ashish
Hi Diaz, Good Morning!
could you please try querying 'pr_data_products' for Hfix-es & 'pr_engineclasses' for external jar imports.
Please share your observations/comments, Thank you!
psahukaru
WellCare
Hi Phani,
I tried querying prd_data_products for hotfixes and it only shows the ones that where done thru the hotfix manager and for the pr_engineclasses yes I am able to see which external jars were imported.
Thank you,
Gareth
WellCare
Hi Gareth,
That is exactly what I was looking for.
Thank you very much for your help.
