Incessant Technologies PVT Ltd
Posted: Mar 4, 2019
Last activity: Mar 8, 2019
Last activity: 8 Mar 2019 10:16 EST
Hi Team,
Can you please help me how to Upgrade/Downgrade JAVA version in Pega.
Please provide the steps/doc to do that.
Thanks & Regards,
Satya.
Before upgrading tech stack, I suggest you to check PRPC compatibility with such change in below guide:
https://community.pega.com/knowledgebase/documents/platform-support-guide
For JRE upgrade, refer following:
https://www.java.com/en/download/help/update_runtime_settings.xml
Within PRPC, there is nothing to be changed when you update JRE from 1.8 to 1.9, its only App server, DB server where you need to point this new JRE.
A thorough testing of PRPC is required after making these changes.
Hi Satya,
I am afraid, the steps to upgrade/downgrade JAVA lies outside scope of PRPC.
That means, we do not provide such steps.
Hi Arvind,
Thank you for your reply. I mean, if I need to upgrade jre version. Let us say, from jre 1.8 to jre 1.9 in pega how can I do that. Can't we do that.
Thanks & Regards,
Satya.
Hi Arvind,
Thank you very much for your reply. I will go through the referred links and will do update the JRE version in App server.
Thanks & Regards,
Satya.
