How to Disable a field until a condition is met
Hello all, I am trying to disable a field until a condition is met. So, in my example I have a Salary field that I want to be greyed out until they check the Employed boolean box. I think that part is good, as I referenced (or called?) the Employed box from the Salary field... using an expression to disable the Salary field when Employed = false.
But, on the Employed boolean field, when I tried to create an event (Click) and an action ??? I got stuck trying different options...none of which worked. But as far as I know, there must be an associated Event and Action set in order for the Disable feature to actually function.
And when I searched the Academy for the word disable, I could not find anything that talked about how to use it... or that even mentions it. I guess my Search skills need improving as well. ;)
Thank you for your time.
Ty
