How to debug Pega Mobile Client & Login Issue
Hi Guys,
Background
I started to develop an Android app (Pega Mobile Client) with an Personal Edition on the version 7.2. I didn't do it from scratch but I exported an application from 7.2.1 und imported it to 7.2. As far as I am concerned, I already did the right configurations regarding enabling the environment for Pega Mobile (Mobilebuildserverrule, Certificates etc.). The application/main case consists of several Single Step Assignments and one Create PDF Utility hence it doesn't use Screenflows.
Problem Description
I succesfully build the app, but only without enabling the cases online. It works though just as the application if you call it from the browser. But as soon as I enable the case offline the application doesn't work anymore. To be precise, I can't login to the app, it only returns "Unable to access the server - login process failed" (something like that). The user credentials are correct and the tomcat doesn't show any error messages or logs.
Hi Guys,
Background
Problem Description
I'm reffering to the following feature https://pdn.pega.com/troubleshooting-pega-mobile-client/troubleshooting-pega-mobile-client#04_viewing_logs , which I unfortunately can't utilize.
My main problem is, that I do not get any useful error messages and / or logs. I already enabled the loggin mechanismn for the Pega Mobile client, and set the log level to "debug", but I don't know how to access them.
So if anyone explains me how to correctly debug the Pega Mobile Client or if you have any ideas why I can't even correctly login to the offline enabled application, that would be nice.
Thanks in advance!
Kind regards
Nam
*NOTE* I can add screenshots if neccesary :)
