How to create common project which has interrogation on its project
I have a project (ex: CommLib.osproj) that has number of automation (EX: CommonLogin.os) which I want to use on other projects.
I could see the Common automation on object explorer after performing operation of "Add Reference" and "Manage Imported Porject" on other projects.
But in the case the commonLib.osproj perform interrogation on its project,
CommonLogin.os doesn't work correctly when called by other projects.
I need this function because I have a number of projects which will access to same web application.
I want to avoid to create loign automation on each porjects becuase its totally same.
