How to convert a pdf file into base64 string
How to convert a file into base64 string.
I want to convert the pdf file to base64 in pega please share the steps
The below snippet retreives the base 64 content.
D_AttachmentContent[AttachInsKey:.ExtractClaimsData.pxAttachmentKey,PopulateAttachStream:"true"]. pyAttachStreamPlease check this article for more details
https://community.pega.com/conversations/user-experience/split-screen-c…
@RameshSangili can you please how to do it in activity. i have list of documents in documentlist and which ever i select it form UI checbox it has to be covert into base64 format and sent to docusign as input parameter
