Areteans
Last activity: 29 Sep 2020 5:28 EDT
How to convert a file into base64 string
How to convert a file into base64 string?
Please provide a sample java code.
Currently I'm trying to use below, but it does not return correct base64 string value.
java.io.File file = new java.io.File("D://Folder1//Folder2//Test.txt");
FileExists=file.exists();
//init array with file length
byte[] bytesArray = new byte[(int) file.length()];
//encode the byte array into Base64.
try
//Base64String = Base64Util.encodeToString(bytesArray);
Base64String = java.util.Base64.getMimeEncoder().encodeToString(bytesArray);
catch (Exception e)
throw new PRRuntimeException("Can't attach the file to the Work Object");
***Edited by Moderator Marissa to update General to Product***
