How can we use, Temporary Object option for the flows other than pyStartCase ?
Hi Team,
I have created a case type AccountCreation and it has pyStartCase has starting processes. In the process tab of pyStartCase, checked the Temporary Object.
I have added StageOne to the AccountCreation case type in case lifecycle and a step to that stage. Then added Persist case smart shape to the StageOne_Process0. Please, refer the screenshots.
In the process tab of StageOne_Process0(flow), whats the use of Temporary Object check box. As checking/unchecking it, there is no difference in creation of workobject.
Excuse me, for the improper flow naming convention.
Hi Kartik,
A temporary case is created and resolved by a single operator, or by straight-through processing, and is not saved as a database object. You can use temporary cases in screen flows and regular flows.
To create a temporary case, select the Creates temporary object? check box on the flow that creates the object.
Evita.
