How can we automate the slider validation in open span?
The control more than likely use some sort of range to determine how much percent of it is slided over. Do you have an example or source to attach?
I took the w3 school example was able to move all the way by setting the control style property to "left: 100%;"
Example: https://www.w3schools.com/jquerymobile/tryit.asp?filename=tryjqmob_forms_slider
Thank you so much Rushabh,
Here is the example of slider source.
Thank you so much for your reply Rushabh,
Here is the source of slider control.
Link: https://account.aliyun.com/register/register.htm
