Deutsche Post AG
DE
Last activity: 11 Sep 2020 4:12 EDT
How can I setup starting time for a scheduler if it runs multiple times a day
If you have a job running monthly, weekly or daily you can configure the start time in the job scheduler.
I need to set up a job running three times a day (every 8 hours). It should run at 7am, 3pm and 11pm. When I use the option "multiple times a day" there is no option to set up an initial start time.
I tried in Dev-Environment and it seems that the first run will be 8 hours after I check in the job scheduler. I wonder what will happen when I move the rule to staging.
How can I set up an initial time for this job scheduler?
