How to call launchLocalAction JS API
Pega has launched JS API for Pega 7.3. However we can use the same API from Pega 7.2.2 if we install Hfix DL-73599 .
We are using Pega 7.2.2 and installed the Hfix . However we are not able to call the local action using the JS API.
We did the following steps
- Created a custom section and added below code
<script type="text/javascript">
pega.api.ui.actions.launchLocalAction("LocalactionName","pega.api.ui.constants.MODAL_DIALOG","onload","Data-Portal","","","ModalTemplateName","","","","","");
</script>
- Added the above section in Header section of the Portal
But when user is logging in the localation is not getting triggred.
Any idea how to call the local action using the API.
