Accenture
how to add xpath to identify the objects in Pega robotics studios 10.80 version
Hi team,
Can you please help me, how can i use xpaths as object locator in open span. I have tried all match rules, facing different issues with different objects.
1. I have a input inside a <td>. i am able to inspect it, but openspan is not adding any properties of it not sure why .I have tried adding matching rules as this input has id and unique name too but did not work
2. The objects can be identified only with the sibling/parent/ancestor id, object itself does not have any unique property, even for these kind of scenario i guess xpath is best solution,
can someone please help? Attached is the screenshot of 1st point.
