How to add modal dialog on Submitting screenflow assignement
Hi everyone! I have a ScreenFlow with 5 assignments. When I submit 5th assignment, I need to evaluate the When rule, and if it is true, I should show a modal dialog with the text "Are you sure?" and two buttons YES/NO. So, if "Yes" - move ahead if "No" - stay here and do nothing How can I implement this? P.S. I tried to implement this way: 1. Run post-processing Activity on flow action 2. Evaluate when in Activity 3. Call ProcessAction with Method parameters: NewTaskStatus -> 'My flow action' i created ActionSection->'My Section' i used in 'My flow action' StreamType / StreamClass -> Rule-HTML-Section bIsModal->true However, modal dialog did not appear.
