Vodafone
Vodafone
Vodafone
Posted: Jul 31, 2025
Last activity: Aug 4, 2025
Last activity: 4 Aug 2025 0:09 EDT
how to add horizontal line to each record in pega constellation view
@VenkateswararaoK Pega Constellation doesn't give a built-in option to add a horizontal line between each record in a list. If you want that kind of styling, you’ll need to create a custom view. The usual way is by building a DX Component where each item is displayed with a line under it either using a <hr> tag or by applying a bottom border with CSS. Once your custom component is ready, you can plug it into the section or view that shows your list. This approach lets you control exactly how each record appears, including adding spacing, styling, or anything else you need. It's a bit of custom work but gives you full flexibility
