How to add a custom edit validate rule and call it from the new harness
we have some fields that needs custom validation (like SSN as example) when the user enters input. The javascript function should be fired on an onchange event. Here are the steps i have followed.
1) Created the CustomValidators.js file in my ruleset. The code is mentioned below
<pega:when test='$SAVE(bClientValidation)=="true"'> <%-- include only when client validation is enabled --%>
<script>
***Moderator Edit: Vidyaranjan | Updated SR details & tagged SR Created***
var ruleEditValidate_ATA = new validation_ValidationType("ATACode", ATACode_Formatter);
ruleEditValidate_ATA.addEventFunction("onchange", ATACode_Formatter);
function ATACode_Formatter(object){
var format = "###-##-####";
if(object.value.length == 9){
dFilter(object,format);
return Format_Validation(object,format);
</script>
</pega:when>
2. The EDIT-VALIDATE rule is created for the ATACode as below
String ATACode = "^(\\d{3})-?\\d{2}-?\\d{4}$";
java.util.regex.Pattern p = java.util.regex.Pattern.compile(ATACode);
java.util.regex.Matcher m = p.matcher(theValue);
String[] strArr = theValue.split("-");
int numDashes = strArr.length - 1;
boolean isATA = m.matches();
if((isATA == false) || (numDashes == 0)){
return false;
<script>
</script>
</pega:when>
return false;
if(theValue.length()!=11) {
return false;
return true;
. The harness should pick up this script. But it is not firing.
Any help is appreciated on how to incorporate custom edit validate rules. Also please let me know if a support request is required for this.
