NCS
SG
Last activity: 27 Dec 2018 12:14 EST
Hazlecast required for standalone setup
Client requirement is to setup two standalone environment without cluster or domain.We have done ear deployment on JBOSS 6.4.21 with standalone-full.xml.During start-up of application server, observed PegaRules log file that, it’s scanning the network and trying to build cluster.
- Clustering technology is mandatory in v7.x?
- Do we really required Hazlecast for standalone setup? If not how to disable it.
- If it’s disable, what are all the implications.
- Is Hazlecast is getting triggered by default to create TcpIpJoiner
PegaRuleLog file
2018-11-30 15:00:10,355 [ ServerName01U] [ STANDARD] [ ] [ ] (ic.toggle.ToggleControllerImpl) INFO - Toggle Controller initialization complete
2018-11-30 15:00:11,308 [ ServerName01U] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Created provisional node: "ServerName01U ServerName 2018-11-30 06:59:46.506 GMT", []
2018-11-30 15:00:11,324 [ ServerName01U] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Starts joining cluster
2018-11-30 15:00:11,574 [ ServerName01U] [ STANDARD] [ ] [ ] (.instance.DefaultAddressPicker) INFO - [LOCAL] [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Interfaces is disabled, trying to pick one address from TCP-IP config addresses: [xxx.xx.xxx.xx9]
PegaRuleLog file
2018-11-30 15:00:11,574 [ ServerName01U] [ STANDARD] [ ] [ ] (.instance.DefaultAddressPicker) INFO - [LOCAL] [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Prefer IPv4 stack is true.
2018-11-30 15:00:11,605 [ ServerName01U] [ STANDARD] [ ] [ ] (.instance.DefaultAddressPicker) WARN - [LOCAL] [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Could not find a matching address to start with! Picking one of non-loopback addresses.
2018-11-30 15:00:11,652 [ ServerName01U] [ STANDARD] [ ] [ ] (.instance.DefaultAddressPicker) INFO - [LOCAL] [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Picked Address[xxx.xx.xxx.xx8]:5701, using socket ServerSocket[addr=/xxx.xx.xxx.xx8,localport=5701], bind any local is false
2018-11-30 15:00:12,058 [ ServerName01U] [ STANDARD] [ ] [ ] (hazelcast.spi.OperationService) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Backpressure is disabled
2018-11-30 15:00:12,074 [ ServerName01U] [ STANDARD] [ ] [ ] (i.impl.BasicOperationScheduler) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Starting with 4 generic operation threads and 8 partition operation threads.
2018-11-30 15:00:12,199 [ ServerName01U] [ STANDARD] [ ] [ ] ( com.hazelcast.system) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Hazelcast 3.4.1 (20150213 - 780828c) starting at Address[xxx.xx.xxx.xx8]:5701
2018-11-30 15:00:12,199 [ ServerName01U] [ STANDARD] [ ] [ ] ( com.hazelcast.system) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Copyright (C) 2008-2014 Hazelcast.com
2018-11-30 15:00:12,199 [ ServerName01U] [ STANDARD] [ ] [ ] ( hazelcast.instance.Node) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Creating TcpIpJoiner
2018-11-30 15:00:12,199 [ ServerName01U] [ STANDARD] [ ] [ ] (azelcast.core.LifecycleService) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Address[xxx.xx.xxx.xx8]:5701 is STARTING
2018-11-30 15:00:12,339 [4f73.cached.thread-1] [ STANDARD] [ ] [ ] ( nio.tcp.SocketConnector) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Connecting to /xxx.xx.xxx.xx9:5701, timeout: 0, bind-any: false
2018-11-30 15:00:12,371 [4f73.cached.thread-1] [ STANDARD] [ ] [ ] (nio.tcp.TcpIpConnectionManager) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1] Established socket connection between /xxx.xx.xxx.xx8:63973 and ServerName02U/xxx.xx.xxx.xx9:5701
2018-11-30 15:00:18,402 [c-operation.thread-3] [ STANDARD] [ ] [ ] (zelcast.cluster.ClusterService) INFO - [xxx.xx.xxx.xx8]:5701 [c13c66c1cbf917091298a5bf8a244f73] [3.4.1]
