Has anyone used OOTB or custom logic to compare two work items (cases)?
Hi.
I wanted to know if there is any OOTB functionality that would allow the comparison of two work items (of the same case type)? or was there custom logic written? (This is not reflective of the duplicate case check as it's just performing a compare of the two work item instances)?
thanks
***Updated by moderator: Lochan to add Category***
Hi Rob,
pxCOmparePages Activity is not available in PRPC 7.1.8. However, you can try using PYCOMPAREFROMRULEDIFF Activity to compare the XML of the workobject.
Ravi
