HSBC
Last activity: 19 Jan 2018 8:57 EST
Getting SAXParseException exception in logs when exeuting Parse XML rule
We are using PRPC 6.1SP2 .
Created a new Parse XML rule and tries to run by providing XML content to check whether it is getting parsed properly or not. We have observed when there is repeating column, it has been allowed only specified length if we increase the content we could see exception in logs as below
Observation: If we decrease the content then it is parsing properly.
sample format of XML for repeating :
<appbody:appdata xmlns:appbody="http:/ ">
<appbody:P xsi:type="xsd:string" name="conversationid">1742509522423U00</appbody:P>
<appbody:P xsi:type="xsd:string" name="bushdr"><![CDATA
[{1:F01HBUKGB4BAXXX0001000001}{2:I103MRMDUS33XXXXN}{3:{108:X3884W100NYK}{119:STP}}{4:
:20:RBD25047KAAJYDZ4
dsfdsfdsf43543545
]]></appbody:P>
<appbody:P xsi:type="xsd:string" name="hash">F01HB1</appbody:P>
</appbody:appdata>
om.pega.pegarules.pub.PRException: Caught exception parsing XML stream
at com.pega.pegarules.integration.engine.internal.mapping.XMLParserBase.parseDocument(XMLParserBase.java:512)
at com.pega.pegarules.integration.engine.internal.mapping.ParseRuleUtils.invokeXMLParseRule(ParseRuleUtils.java:250)
at com.pega.pegarules.integration.engine.internal.mapping.ParseRuleUtils.invokeXMLParseRule(ParseRuleUtils.java:212)
dsfdsfdsf43543545
]]></appbody:P>
</appbody:appdata>
Caused by:
org.xml.sax.SAXParseException: Content is not allowed in prolog.
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at com.pega.pegarules.integration.engine.internal.mapping.XMLParserBase.parseDocument(XMLParserBase.java:507)
... 62 more
