Cognizant
Cognizant
Cognizant
Posted: Apr 30, 2018
Last activity: May 1, 2018
Last activity: 1 May 2018 13:13 EDT
Getting SAXParseException while parsing the XML
Getting below exception while parsing the XML and any suggestions pls.
2018-04-30 16:07:14,247 [GASITWorkManager : 7] [ STANDARD] [ ] [ ANZPRS:05.01.01] ( mapping.xml.XMLParserBase) ERROR - Caught exception parsing XML stream org.xml.sax.SAXParseException: XML document structures must start and end within the same entity. at org.apache.xerces.parsers.DOMParser.parse(Unknown Source) at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source) at com.pega.pegarules.integration.engine.internal.mapping.xml.XMLParserBase.parseDocument(XMLParserBase.java:507) at com.pega.pegarules.integration.engine.internal.mapping.ParseRuleUtils.invokeXMLParseRule(ParseRuleUtils.java:256) at com.pega.pegarules.integration.engine.internal.util.PRParseUtils.parseXML(PRParseUtils.java:119) at com.pegarules.generated.activity.ra_action_parsenppgwheader_15df900b981fd05e869e588276a5ecb8.step3_circum0(ra_action_parsenppgwheader_15df900b981fd05e869e588276a5ecb8.java:349) at com.pegarules.generated.activity.ra_action_parsenppgwheader_15df900b981fd05e869e588276a5ecb8.perform(ra_action_parsenppgwheader_15df900b981fd05e869e588276a5ecb8.java:109) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10587)
This will come when the xml file is not well formed.
See https://stackoverflow.com/questions/37116985/error-xml-document-structures-must-start-and-end-within-the-same-entity
