Ford Motor Company
Posted: June 22, 2018
Last activity: July 6, 2018
Last activity: 6 Jul 2018 9:34 EDT
Getting DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out. | SQL Code: 0 | SQL State: HY008
We are facing DB locktime out error while opening view from Case type, its keep getting the below exception.
Show More
2018-06-22 09:18:24,018 [ TP_http : 436] [TABTHREAD1] [ ] [ TestJawa:01.01.01] ( rd.queryexec.SqlQueryExecutor) ERROR wwwdev.tracklite.ford.com|xx.xx.xx.xx abc@xx.com - An error occured on executing the query for the report definition - There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out. DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out. | SQL Code: 0 | SQL State: HY008 com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out. DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out. | SQL Code: 0 | SQL State: HY008 at com.pega.pegarules.data.internal.access.ExceptionInformation.createAppropriateExceptionDueToDBFailure(ExceptionInformation.java:379) ~[prprivate.jar:?] at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:358) ~[prprivate.jar:?]
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out.
2018-06-22 09:18:24,021 [ TP_http : 436] [TABTHREAD1] [ ] [ TestJawa:01.01.01] ( rd.queryexec.SqlQueryExecutor) ERROR wwwdev.tracklite.ford.com|xx.xx.xx.xx abc@xx.com - Query: WITH rr_inheritance_pc0 AS ( SELECT "r".pzInsKey, "r".pyRuleAvailable, "r".pyClassName, "r".pyRuleSet, RANK() OVER (PARTITION BY "r".pxInsId, "r".pyClass ORDER BY "c".pxHeight, "i"."pzRuleSetIndex", "r".pyRuleSetVersion DESC) AS "rank_idx", DENSE_RANK() OVER (ORDER BY "r".pxInsId, "r".pyClass) AS "group_idx" FROM Rules.pr4_rule_vw "r" INNER JOIN Rules.pr_sys_class_ancestors "c" ON ("r".pyClassName = "c".pxClassName) INNER JOIN ( SELECT "i".pzRuleSetName AS "pzRuleSetName", "i".pzRuleSetIndex AS "pzRuleSetIndex", "i".pzRuleSetVersionMajor AS "pzRuleSetVersionMajor", "i".pzRuleSetVersionMinor AS "pzRuleSetVersionMinor", "i".pzRuleSetVersionPatch AS "pzRuleSetVersionPatch" , "i".pzRuleSetVersionMinorPatch AS "pzRuleSetVersionMinorPatch" FROM Rules.pr_sys_ruleset_index "i" WHERE "i".pzRuleSetListHash = ? UNION ALL SELECT CAST(? AS VARCHAR(128)) AS "pzRuleSetName", -1 AS "pzRuleSetIndex", 1 AS "pzRuleSetVersionMajor", 1 AS "pzRuleSetVersionMinor", 1 AS "pzRuleSetVersionPatch" , '01-01' AS "pzRuleSetVersionMinorPatch" ) "i" ON ("r".pyRuleSet = "i"."pzRuleSetName") AND ("r".pzRuleSetVersionMajor = "i"."pzRuleSetVersionMajor" AND "r".pzRuleSetVersionMinorPatch <= "i"."pzRuleSetVersionMinorPatch") WHERE "r".pyClass = ? AND "c".pxLeafClassName = ? AND "r".pyRuleAvailable != 'No' AND "r".pyCircumstanceType IS NULL AND "r".pyRuleStarts IS NULL AND "r".pyRuleEnds IS NULL AND "r".pzClassType = 0 ) , bc_inheritance_pc0 AS ( SELECT "bc".pzInsKey FROM ( SELECT "tmp".pzInsKey, "tmp".pyRuleAvailable FROM ( SELECT "second".pzInsKey, "second".pyRuleAvailable, RANK() OVER (PARTITION BY "second"."group_idx" ORDER BY "second"."rank_idx") AS "finalRank" FROM rr_inheritance_pc0 "first" RIGHT OUTER JOIN rr_inheritance_pc0 "second" ON ( "first"."group_idx" = "second"."group_idx" AND "first".pyClassName = "second".pyClassName AND "first".pyRuleSet = "second".pyRuleSet AND "first".pyRuleAvailable = 'Withdrawn' AND coalesce("first"."rank_idx", 0) <= "second"."rank_idx" ) WHERE "first"."rank_idx" IS NULL ) "tmp" WHERE "tmp"."finalRank" = 1 ) "bc" WHERE "bc".pyRuleAvailable != 'Blocked' ) , rr_wo_inheritance_pc0 AS ( SELECT "r".pzInsKey, "r".pyRuleAvailable, "r".pyClassName, "r".pyRuleSet, RANK() OVER (PARTITION BY "r".pxInsId, "r".pyClass ORDER BY "i"."pzRuleSetIndex", "r".pyRuleSetVersion DESC) AS "rank_idx", DENSE_RANK() OVER (ORDER BY "r".pxInsId, "r".pyClass) AS "group_idx" FROM Rules.pr4_rule_vw "r" INNER JOIN ( SELECT "i".pzRuleSetName AS "pzRuleSetName", "i".pzRuleSetIndex AS "pzRuleSetIndex", "i".pzRuleSetVersionMajor AS "pzRuleSetVersionMajor", "i".pzRuleSetVersionMinor AS "pzRuleSetVersionMinor", "i".pzRuleSetVersionPatch AS "pzRuleSetVersionPatch" , "i".pzRuleSetVersionMinorPatch AS "pzRuleSetVersionMinorPatch" FROM Rules.pr_sys_ruleset_index "i" WHERE "i".pzRuleSetListHash = ? UNION ALL SELECT CAST(? AS VARCHAR(128)) AS "pzRuleSetName", -1 AS "pzRuleSetIndex", 1 AS "pzRuleSetVersionMajor", 1 AS "pzRuleSetVersionMinor", 1 AS "pzRuleSetVersionPatch" , '01-01' AS "pzRuleSetVersionMinorPatch" ) "i" ON ("r".pyRuleSet = "i"."pzRuleSetName") AND ("r".pzRuleSetVersionMajor = "i"."pzRuleSetVersionMajor" AND "r".pzRuleSetVersionMinorPatch <= "i"."pzRuleSetVersionMinorPatch") WHERE "r".pyClass = ? AND "r".pyRuleAvailable != 'No' AND "r".pyCircumstanceType IS NULL AND "r".pyRuleStarts IS NULL AND "r".pyRuleEnds IS NULL AND "r".pzClassType = 1 ) , bc_wo_inheritance_pc0 AS ( SELECT "bc".pzInsKey FROM ( SELECT "tmp".pzInsKey, "tmp".pyRuleAvailable FROM ( SELECT "second".pzInsKey, "second".pyRuleAvailable, RANK() OVER (PARTITION BY "second"."group_idx" ORDER BY "second"."rank_idx") AS "finalRank" FROM rr_wo_inheritance_pc0 "first" RIGHT OUTER JOIN rr_wo_inheritance_pc0 "second" ON ( "first"."group_idx" = "second"."group_idx" AND "first".pyRuleSet = "second".pyRuleSet AND "first".pyRuleAvailable = 'Withdrawn' AND coalesce("first"."rank_idx", 0) <= "second"."rank_idx" ) WHERE "first"."rank_idx" IS NULL ) "tmp" WHERE "tmp"."finalRank" = 1 ) "bc" WHERE "bc".pyRuleAvailable != 'Blocked' ) , non_rr_rules_pc0 AS ( SELECT "r".pzInsKey FROM Rules.pr4_rule_vw "r" WHERE COALESCE("r".pyRuleAvailable, 'Yes') != 'No' AND "r".pyCircumstanceType IS NULL AND "r".pyRuleStarts IS NULL AND "r".pyRuleEnds IS NULL AND "r".pzClassType = 2 ) , resolved_rules_pc0 AS ( SELECT pzInsKey FROM bc_inheritance_pc0 UNION ALL SELECT pzInsKey FROM bc_wo_inheritance_pc0 UNION ALL SELECT pzInsKey FROM non_rr_rules_pc0 ) SELECT "PC0"."pyPropertyName" AS "pyPropertyName" , "PC0"."pxInsId" AS "pxInsId" , "PC0"."pyLabel" AS "pyLabel" , "PC0"."pyRuleSet" AS "pyRuleSet" , "PC0"."pzInsKey" AS "pzInsKey" FROM Rules.pr4_rule_property "PC0" INNER JOIN resolved_rules_pc0 "resolved_rules_pc0" ON ("PC0".pzInsKey = "resolved_rules_pc0".pzInsKey) WHERE ( "PC0"."pyClassName" = ? ) AND "PC0"."pxObjClass" = ? ORDER BY 3 ASC 2018-06-22 09:18:56,881 [ TP_http : 443] [TABTHREAD1] [ ] [ TestJawa:01.01.01] ( rd.queryexec.SqlQueryExecutor) ERROR wwwdev.tracklite.ford.com|xx.xx.xx.xx abc@xx.com - An error occured on executing the query for the report definition - There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out. DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out. | SQL Code: 0 | SQL State: HY008 com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out. DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out. | SQL Code: 0 | SQL State: HY008
Show Less
