Getting the current and next index in a PageList
I am unable to retrieve the index in a pagelist using the methods described in the thread
https://community1.pega.com/community/product-support/question/getting-current-index-pagelist
The 'pxListSubscript' and 'PageListIndex' are not returning correct values. What I am doing wrong?
(FYI ... ONLY when I did not find values in Step 1.1.1 did I try step 2 and then finally step 3. Please do not assume I am overwriting the value in the final step.)
The pic below is representative of what is happening in my DT and how ONLY step 3 using pyForEachCount solved the issue.
In the code above when my when condition is true, I want to pick up the index at that point.
Only param.pyForEachCount is returning the correct value. The 'pxListSubscript' and 'PageListIndex' are not returning correct values. What I am doing wrong?
My 'TestIndexValue' is an integer property.
But when I do 'param.pyForEachCount +2' , what I see on the clipboard is 42 and not 6.
How do I increment the returned value from the pagelist index? Any insight would be appreciated.
