Synechron
Last activity: 28 Mar 2017 6:27 EDT
Generated PDF font size issue OOTB feature
I am currently working on Pega 6 and when I try to export to PDF for a generated Report via report definition I am having font size issue, the font size becomes very small and hence is not readable. Every time I will have to zoom it manually.
Is there any solution for it.
Attaching screen shot of generated PDF
Thanks in advance.
Synechron
Please refer
https://community.pega.com/support/support-articles/htmltopdf-generates-very-small-fonts-output-pdf
Hope this helps.
Best Regards,
Mounika
If there are more columns in the report definition, inorder to accomodate all the columns, the font size will be reduced in the generated pdf .
Check if customizing the rule pyReport_ExportToPdfStyles works ?
Synechron
Hi Haritha,
Yes it is trying to accommodate everything in 1 page and hence reducing the font size, but I don't want it to happen. If it does not fit in one page that is okay, it can create multiple pages but that will make the records readable.
and I did not find the rule name you mentioned.
I could find the rule ![]()
What is the prpc version ?
Synechron
Hi Haritha,
I am working on Pega 6.2.
Synechron
I get this when I try to search the rule name you mentioned
Synechron
Also when I has more number of records like I had 580 records. It accommodated in just 3 pages and the font size was very small. If it has accommodated the results into 12-15 pages it would have been perfect.
Infosys
It seems like there are too many columns in the output and it tries to fit everything in the PDF output . This seems to be expected . Try changing the layout to landscape if not already and see if it helps.
Synechron
Cannot be done. Its the expected behavior.
