Generate Multiple PDF's on click of a button
Hi PEDEL,
We need to generate two PDF's on click of a button and attach them to the case. We are calling an activity 'A' twice to generate 2 PDF's which has the below steps in it.
Property-Set-HTML
HTMLToPDF
Code-Pega-PDF.View
Code-Pega-PDF.AttachToWork
We are passing different Params to this acticity A for generating both the PDF's. We could see two PDF's are generated but only the last one is being attached to the case. Please advice what could be the issue ? Also, we have integration with Alfresco CMIS and the two attachments are seen in the CMIS folder too. Why are both the PDF's not being attached ? Why is the second one overriding the first PDF ?
Theja
Hi Theja,
Can you please try pyAttachAsPDF activity in place of AttachtoWork activity and let me know the response.
