Geeting this error - Publish failed.Please verify the path details.Forbidden when Using Export wizard to upload zip file at repository
I am getting this error - Publish failed.Please verify the path details.Forbidden. I am using Export UI wizard to prepare build - zip file and passing Export to repository but it creates only a mark at repository server with 0 byte size. Any help is appreciated. The user used in repository setting has PUBLISh privilege at repository server - this I have validated manually after logging through that user, directly at repository server.
***Edited by Moderator Marissa to update platform capability tags; update SR details****
