File Parser (CSV) Replacing characters when parsing
Version : Pega 7.3.1
I am having issues with File parser. I am using CSV file, when i import file PEGA is converting space(' ') to underscore('_') and backslash('/') to underscore('_').
I tried different encoding options but still the same issue. Any thoughts/help?
Thank You
Found the root cause. ParseCSVHeader function only takes Alpha Numeric characters. working on a workaround solution.
Thank You
