Federation of databases (7.2.1 running Windows with SQL database split-schema to 7.1.6 running AIX with DB2 database single-schema)
This is really a multiple part question.
1. Does anyone have any documentation on how to Federate databases and the requirements?
2. Is there a way to federate a 7.2.1 running on Windows with a SQL database in split-schema to a 7.1.6 system runiing on AIX with a DB2 single-schema instance?
3. What benefits would we get from Federation of the databases?
Thanks for the details. The only product coming to mind that multiple pega instances can work together is called federated case management (https://collaborate.pega.com/question/federated-case-management-fcmhow-operator-authentication-and-authorization-works), but I am not sure it is what your management talked about. Maybe you can give us the pega contact (names) your management had at PegaWorld, we can then follow up here at Pega to understand more about the background. That way, we can give a much clearer guidance.
