CGI
SE
Last activity: 27 Dec 2018 12:10 EST
Failed to launch harness on button after file upload.
Getting below error message on launch of harness .
Configuration:
1) Upload file feature is configured in grid layout to attach file for each repeating list .Upload file model dialogue is getting launched on pyWorkPage .
2) On top of grid view , we have a layout that contains view attachment button to review or edit all attachments that are uploaded through grid view. But System is failing the launch the harness once at-least one file is uploaded from repeating grid list as getting mentioned below error message. Even i tried launch blank harness which contains no stream rules but still failing to launch harness .
Working scenario:- if upload file feature is configured in header level (not in repeating grid ) then view attachments feature is working as able to view all attachments in harness .
Attached the detail document for configurations .Attached the log file as well.
Error message
Display error
Error trying to process
L-XXXXX
Action that failed
DisplayDocCategoryAttachments
For class
XXX-XXX-Work-XXXX-XXX
Current operator
XXXX
Object key
Configuration:
Error message
Display error
L-XXXXX
Action that failed
For class
Current operator
XXXX
Object key
Read/Write
InputEnabled
Error message
Section 'DisplayDocCategoryAttachments' execution error on page 'pyWorkPage' of class 'XXX-XXXX-Work-XXXX-XXX'. : Section 'WorkFormStandard' execution error on page 'pyWorkPage' of class 'XXX-XXXX-Work-XXXX-XXX'. : Section 'UserWorkForm' execution error on page 'pyWorkPage' of class 'XXX-XXXX-Work-XXXX-XXX'. : The property pyWorkPage.pyWorkPage was of mode Page while com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.getStringValue() was expecting String mode. Details: (none)
