JPMorgan Chase
Last activity: 6 Sep 2017 7:18 EDT
Exporting Product file using Jenkins fails second time
Hi
I have created a product rule, for first time I was able to export the product file using Jenkins Build successfully. However when I try with the same product rule and version without any changes, subsequent builds for export are failing.
No matching Product or Application found with inputs Product Name:TestJenkins Product Version:01-01-01
Has anyone faced this kind of issue. Any thoughts?
Sam
***Updated by moderator: Lochan to create branched post***
Hi Samanth,
Thanks for sharing the requested information. As per the information available in the Failure.txt log file you specified below product version,
But if you observe the Success.txt log file the product version is 01.01.01 as shown below,
Also if you observe your Product rule the version of product is 01.01.01 not 01-01-01
Kindly change the product version to 01.01.01 then your export will work successfully.
Regards
Mahesh
