Error with Jenkins Integration Export
I am attempting to use the prpcServiceUtils to import and export applications using Jenkins. I have been able to import an application from a RAP stored on the local file system, but have not been able to export the application successfully.
I am not seeing any errors within the PegaRules log. I only receive the following from Jenkins:
opt/prpc/prpcServiceUtils_73/scripts/utils/prpcServiceUtilsWrapper.xml:180: The following error occurred while executing this line:
/opt/prpc/prpcServiceUtils_73/scripts/utils/prpcServiceUtilsWrapper.xml:198: Java returned: 1
I do see this in the PegaRules Alert Log:
ServicePAL.Rest.SystemManagement.v2.Export*
Rule-Obj-Activity:InitialProfileSetup*
PEGA-REMOTEMANAGEMENT-EXPORT PZEXPORTSERVICEJSONWRAPPER #20160726T223503.485 GMT Step: 8 Circum: 0*NA*****
pxRDBIOElapsed=0.79;pxListWithUnfilteredStreamCount=75;
pxDeclExprCtxFreeUseCount=21,107;
pxRDBIOCount=74;
pxListWithoutStreamCount=15;
pxServiceActivityElapsed=384.04;
pxTotalReqCPU=336.11;
pxRunModelCount=137;
pxRunWhenCount=192;
pxDeclarativePageLoadElapsed=0.12;
pxRulesExecuted=29,582;
pxListRowWithUnfilteredStreamCount=16,942;
pxOtherCount=17,137;
pxDBInputBytes=1,246,345,222;
pxTotalReqTime=435.80;
pxActivityCount=57;
pxAlertCount=1;
pxOtherFromCacheCount=26;
pxRDBWithoutStreamCount=65;
pxExceptionCount=4;
pxRunOtherRuleCount=1;
pxDeclarativeRulesInvokedCount=26,424;
pxInteractions=1;pxRuleCount=7;
pxServiceOutMapReqElapsed=0.00;
pxInputBytes=225;
pxDeclarativeRulesInvokedElapsed=4.43;
pxRuleIOElapsed=0.01;
pxServiceCount=1;
pxRulesUsed=50,071;
pxDeclarativePageLoadCount=4;
pxDeclExprCtxSensUseCount=517;
pxListRowWithoutStreamCount=31;
pxProceduralRuleReadCount=1;
pxRuleFromCacheCount=6;
pxOtherIOElapsed=46.31;
pxTrackedPropertyChangesCount=11,957;
pxDBOutputBytes=6,590,780;
pxRDBRowWithoutStreamCount=14,771;
pxOtherIOCount=17,468;
pxServiceDataVolume=225;*NA*NA*NA*NA*NA*NA*
RULE-SERVICE-REST SYSTEMMANAGEMENT V2!EXPORT #20160929T222616.812 GMT has exceeded the threshold of 1,000 ms: 435,802 ms;
pxServiceInMapReqElapsed=0;
pxServiceOutMapReqElapsed=1;
pxServiceActivityElapsed=384036;
pxParseRuleTimeElapsed=0;*
Any help would be appreciated.
