PEG
Exercise: Proposition Management
In step 5.b of the solution, I click "Manage Propositions". A new window appears, but nothing appears in this window. I'm using IE 11.
What am I doing wrong?
PEG
That gave me the idea that I needed.
My Java plug-in wasn't installed correctly. I reinstalled it, and now I can see VBD.
Thanks for the help!
May I ask you which exercise exactly are you using? I did check in the: PEGA DECISION MANAGEMENT ESSENTIALS (7.13), The Importance of Propositions lesson, and exercise: Proposition Management (in the section Practicing What You Learned) and I see at the exercise Step 5b:"Examine “Save views” and select “Manage Propositions to launch Visual Business Director."
Miki
PEG
Yes, that is the correct step of what I'm trying to do.
TURBT,
When you compare your exercise progress with the exercise Solution Video, at what point in the video (mm:ss) do you not see what you are expecting to see?
Marco.
PEG
When I click Manage / Saved Views / Manage Propositions.
TURBT,
Okay, now it is clear thanks.
So it looks like Visual Business Director is not working for you. Are you using prpc.local to access the Pega Marketing Enablement 7.13 exercise system?
Marco.
PEG
Please try this:
1. Click on the 'Start' windows botton, and in the 'Search programs and files' type in: 'Configure Java'
2. In the Java control panel enable logging, by checking the Enable logging check box in the Debugging section.
3. Send us the email with the result of the console window which wil open after you click on the ''Manage Propositions' link.
Miki
PEG
TURBT,
Thanks a lot for sharing the solution.
Marco.
Accenture
This might be a dumb Question, But what is the password for the User SystemArchetect@PropositionsManagement? The lesson shows a video but I can't log in to practice this lesson.
Justin,
You did misspell the operator. Please take it as given in the exercise. Moreover, ensure you imported the EnvironmentSetup.zip file first.
Miki
Justina,
Thanks for your post.
You can find the credentials at the top of the exercise.
Marco.
