Exception in thread "PEGARULES PASSIVATIONDAEMON" java.lang.OutOfMemoryError: GC overhead limit exceeded
Upgrading from 6.3.1 to 7.3.1 , while deploying prweb.war on JBOSS 7.0 getting the above error... Can any one help me out.
Attaching server.log file, I have seen some more errors in the log, please suggest me if any other configuration file needs to be edited
As part of configuration I have changed STANDALONE.CONF.BAT and web.xml as below
set "JAVA_OPTS=%JAVA_OPTS% -Xms4096m –Xmx8192m -XX:PermSize=512m – XX:MaxPermSize=1024m"
set "JAVA_OPTS=%JAVA_OPTS% -XX:MetaspaceSize=96M -XX:MaxMetaspaceSize=256m"
set "JAVA_OPTS=%JAVA_OPTS% -XX:-UseParallelGC"
set "JAVA_OPTS=%JAVA_OPTS% -verbose:gc -Xloggc:gc.log -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -XX:+CMSClassUnloadingEnabled"
set "JAVA_OPTS=%JAVA_OPTS% -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000"
set "JAVA_OPTS=%JAVA_OPTS% -Dsun.rmi.dgc.server.gcInterval=3600000"
web.xml changes
added
web.xml changes
added
<lookup-name>java:jboss/PegaRULES</lookup-name> to <resource-ref id="ResourceRef_1">
<lookup-name>java:jboss/ AdminPegaRULES</lookup-name> to <resource-ref id="ResourceRef_2">
