MBRDI
Last activity: 22 Jun 2017 1:58 EDT
exception during invocation of method "onMessage" The MDB Listener Service activity is not being called.
When we put the message in the queues, We are observing the below error and service activity is not being called. Whenever there is a message in queue, it encounters below mentioned error and listeners stop running in WAS.
Please advise.
Steps followed
Please advise.
Steps followed
- Created the connection factory and queues in WAS
- Used JNDI names in configuring the JMS MDB Listener (Destination Queue JNDI name)
- Updated the ejb-Jar.xml in the prbeans.jar (using 7zip)
- Updated the application and used add/replace module of WAS and deployed the updated prbeans.jar
- Used Listener ports for binding the listeners and enterprise beans
- Imported the Jar files in Pega - com.ibm.mq.connector.jar, com.ibm.mq.jar, com.ibm.mq.jmqi.jar
- Restarted the servers
[15/06/17 13:26:24:858 CST] 0000017a MDBListenerIm I WMSG0042I: MDB Listener MBLCCMSMaterDataListener started successfully for JMSDestination jms/MBLCMasterData
[15/06/17 13:26:24:889 CST] 00000088 SystemOut O 2017-06-15 13:26:24,889 [stenerThreadPool : 0] [ STANDARD] [ ] [ ] ( etier.mdb.PRJMSListener) ERROR - PRPC Engine invocation failed, javax.ejb.EJBException: Unable to locate implementation of PegaRULES Engine class for EngineCMT
[15/06/17 13:26:24:889 CST] 00001371 PRBootstrap E com.pega.pegarules.internal.bootstrap.PRBootstrap Problem during method invocation (onMessage)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRJMSListener.callEngine(PRJMSListener.java:200)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRJMSListener.init(PRJMSListener.java:175)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRJMSListener.onMessage(PRJMSListener.java:122)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:94)
[15/06/17 13:26:24:889 CST] 00001371 LocalExceptio E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "onMessage" on bean "BeanId(prpc_j2ee14_ws#prbeans.jar#MBLCCMSMasterDataListener, null)". Exception data: java.lang.reflect.InvocationTargetException
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:619)
at com.ibm.ejs.jms.listener.ServerSessionDispatcher.dispatch(ServerSessionDispatcher.java:47)
at com.ibm.ejs.container.MDBWrapper.onMessage(MDBWrapper.java:100)
at com.ibm.ejs.container.MDBWrapper.onMessage(MDBWrapper.java:132)
at com.ibm.ejs.jms.listener.ServerSession.run(ServerSession.java:581)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1864)
Caused by: java.lang.RuntimeException: Problem during method invocation (onMessage)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
at com.pega.pegarules.internal.etier.mdb.PRJMSListenerBoot.onMessage(PRJMSListenerBoot.java:91)
at com.ibm.ejs.jms.listener.MDBWrapper$PriviledgedOnMessage.run(MDBWrapper.java:309)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:63)
at com.ibm.ejs.jms.listener.MDBWrapper.callOnMessage(MDBWrapper.java:266)
at com.ibm.ejs.jms.listener.MDBWrapper.onMessage(MDBWrapper.java:235)
at com.ibm.mq.jms.MQSession$FacadeMessageListener.onMessage(MQSession.java:133)
at com.ibm.msg.client.jms.internal.JmsSessionImpl.run(JmsSessionImpl.java:2799)
at com.ibm.msg.client.jms.internal.JmsXAQueueSessionImpl$1.run(JmsXAQueueSessionImpl.java:1007)
at com.ibm.mq.jms.MQSession.run(MQSession.java:958)
at com.ibm.ejs.jms.JMSSessionHandle.run(JMSSessionHandle.java:1056)
at com.ibm.ejs.jms.listener.ServerSession.connectionConsumerOnMessage(ServerSession.java:1090)
at com.ibm.ejs.jms.listener.ServerSession.onMessage(ServerSession.java:760)
at com.ibm.ejs.jms.listener.ServerSession.dispatch(ServerSession.java:726)
... 9 more
Caused by: javax.ejb.EJBException: Unable to locate implementation of PegaRULES Engine class for EngineCMT
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
... 22 more
[15/06/17 13:26:24:905 CST] 00001371 ServerSession E com.ibm.ejs.jms.listener.ServerSession run WMSG0036E: Maximum message delivery retry count of 0 reached for MDB MBLCCMSMasterDataListener, JMSDestination jms/MBLCMasterData, MDBListener stopped
[15/06/17 13:26:24:936 CST] 000218d9 MDBListenerIm I WMSG0043I: MDB Listener MBLCCMSMaterDataListener stopped for JMSDestination jms/MBLCMasterData
