Wells Fargo
Last activity: 6 Feb 2018 7:52 EST
ExaData DB migration Questions
We are planning to migrate our Oracle DB to oracle ExaData DB, Will Pega support ExaData DB ? on Pega V7.2.1 & V7.3.1, If so can you please help us with below questions/Clarifications:
1) Pega7 7.2.1 and 7.3.1 - Current Oracle database uses UTF8 Charset in the database. Is AL32UTF8 a supported character set for operating with an Oracle DB?
2) Pega 7 7.2.1 and 7.3.1 - Is “oracle advance compression” compatible with Pega – should this feature be disabled?
3) Pega7 7.2.1 Installation instructions contains a note about “Java enablement” when installing/configuring the oracle database. Please find/provide the excerpt with the Oracle settings that are discussed in the install documentation.
Rajesh
