Error while configuring Repository instance (JFrog Artifactory)
I am trying to configure a Repository instance for 'JFrog Artifactory' in Pega Platform v7.4.
Under the Configuration -> Connection Details section, there is a field 'Repository key'.
I am unable to figure out the syntax of the value for this field.
The Pega Help article says the value should be the root location on the JFrog server under which all artifacts are stored. But what should be the syntax is not specified. I am getting error "There was an issue during checking if a file or directory exists." against whatever value I give under this field.
Can anyone please help on this?
