Error: Queue Processor: <QP name> can not be started. Nodes of Web User type are not present in cluster
Greetings. Hope you are well! I started getting error when trying to start a Queue Processor as below, I am not sure if there is a limit on how many Queue Processors can be associated with a Node Type. Can someone please let me know what is causing this error and how to resolve this?
We have 16 Web User Nodes in the cluster and all these QPs have 20 partitions altered via pxAlterStreamPartitions.
Bharat
Hi, Greetings. As i have mentioned there is no restriction on what Node Type a QP can be associated with but as per best practices, it not recommended to associate it with a Web User. However the error i have mentioned has nothing to do with node type association or availablity of nodes in a cluster (these are in cluster). There is a DSS setting to have maximum of 10 default Data Flow runs on Web User and Batch however unlimited on BackgroundProcessing, Search and RTDG. As QP reply on Data flows in the backend, this default setting was causing the error.
Resolution: Increase the default data flow runs active at a time to >10 (see below)
Any questions, please do not hesitate to message me.
Bharat
