CenturyLink
Last activity: 13 Jun 2019 21:36 EDT
Enhancement Request - Build / Deploy Robotic Studio Solution from Console / Command Prompt
We would like to be able to build our Robotic Studio solutions from the command line easily, using a method that doesn't need constant update. We are aware of the option to copy the Robotic Studio build/deploy output commands that use Pega's OSC/OSD executables, and place those into a separate script to build a solution outside of Robotic Studio. However, this method requires updating the build script any time new references or components that use previously non-referenced assemblies are added to the solution.
I noticed that there are many posts in this forum requesting information on HOW to do this, but I saw none that were officially requesting this as an enhancement. Below are a few of the posts:
https://collaborate.pega.com/question/how-deploy-project-command-line
https://collaborate.pega.com/question/openspan-deployment-command-line
https://collaborate.pega.com/question/deploy-project-using-command-line
https://collaborate.pega.com/question/command-build-openspan-solution-using-msbuild
Please make this feature available in a form that doesn't require constant update for Pega Robotic Studio / Plugin solutions.
Thank You.
