Emulator iSeries Access by IBM for AS400 compatibility with Robotics
Although, iSeries Access emulator (image attached) doesn't appear in the matrix of compatible emulators (http://help.openspan.com/80/index.htm#Text_Adapters/Attachmate_Rumba_WRQ_Applications.htm) I was wondering about its compatibility in order to build automations with robotics.
The points that make me have doubts are:
- In the installation folder of the emulator I have found the following libraries: WHLAPI32.dll and EHLAPI32.dll
- The emulator manages sessions, what I mean it is possible to execute the emulator for a "*.ws" (instead of "*.edp" file) file that contains session data like server, port, etc.
So, do you think iSeries Access is compatible with robotics?
Obviously, I haven't got the emulator to test it.
Thanks a lot
This emulator is supported. Choose the PComm Text adapter when working with it.
