Embedded Document processing using File Upload Control
Hi Team,
We have a use case where we want to upload a File which could contains multiple files inside it.
This could be a ".msg" file or a word documents and upon uploading this type of document using Pega File Upload control it should process all of the embedded documents and files Separately into an individual case type so let say one ".msg" file has 5 attachments then there should be 6 case types get created for all of the documents.
Is there any Pega OOTB or solution available for this requirement.
